Raptor carb/filter mods
Old Jan 27, 2003 | 06:47 PM
Raptor010101's Avatar
Default Raptor carb/filter mods
Who makes the outerwear that fits over the top???? I don't understand, why is it ok to have a snorkel that does not have an outerwear but the top does???
02 Raptor
Old Jan 27, 2003 | 06:52 PM
raptor03's Avatar
Remove the Snorkel and the whole lid if you want to put the outerwear over the top of the lid..If you are worried about the water then dont remove the lid,I try to stay out of the water...But for best results i think removing the lid you get the best hpJMO
Old Jan 27, 2003 | 09:54 PM
jraptor's Avatar
raptor03 what clip on the needle jet 4th or 5th
i have the sam setup yamaha jet kit full yoshi but with a k&N filter no lid
i have that low end stumble
165/160 25 pilots + 5th clip (4th clip i loose top end)
02 raptor
i`m at sea level
Old Jan 27, 2003 | 11:48 PM
sixsixT's Avatar
Raptor03 and I are both running the clip in the 3rd groove. Sounds like you might need to go up on your mains also.
Old Jan 28, 2003 | 12:04 AM
  #15
sixsixT's Avatar
Raptor010101 for some reason I can't send PM's so the answer to your question is the october issue. I've tried looking on line before and could not find it. The one on line is the race series that's why it's so much.
Old Jan 28, 2003 | 01:02 AM
  #16
SIXSIXT Sorry You lost me, the answer to what ? and the oct issue of what??
Old Jan 28, 2003 | 11:07 AM
  #17
RaptorRacer1's Avatar
jraptor -
I have a similar setup to you - Yosh Full Comp System, Pro'Flow foam filter, no lid.
I spent all last year farting around with jetting, tried everything from 150-175, moved the needle all around. Nothing worked just right. I finally figured it out and it runs like a BEAST!
25 pilots
175/180 mikuni mains
stock needles on third (middle) clip
fuel screws - start at 1&1/2, go out until it does not pop and fart when you let off the gas, mine is around 3 turns
If you are losing top end when you lower the needle to the 4th clip, that is because you are relying on the needle for gas up there. You should be relying on the main jet for top end.
Good Luck!!
RR1
Old Jan 28, 2003 | 11:38 AM
  #18
03Raptor's Avatar
I just installed the Dynojet kit and Uni Proflow yesterday plus I have the Pro Circuit t-4 slip on. So far I'm happy with it. I haven't carved into my air lid yet....but that may be next.
I'm at 2906' elev. Using the the 4th needle clip and running the DJ146 and DJ144. It seems to carry power all the way through with great throttle responce.
Anybody else running the same setup but with air box mods? I'd like to know if it's worth cutting into the lid.
Shane
Old Jan 28, 2003 | 05:34 PM
  #19
likestogofast's Avatar
Ok - big question here!!! Are the DynoJet DJ series jets the same numbering/fuel flow as the stock Mikuni (Yam dealer) jet numbering/fuel flow??? Maybe that's our problem if they are not. We have been trying to get the top end jetting worked out and it doesn't seem to be quite right. We started with the DJ kit needles, springs, etc., but with 165/160 Mikuni mains. Seems rich on the bottom end and a bit lean up top, even with the needles at 4th clip.
Old Jan 28, 2003 | 08:15 PM
  #20
03Raptor's Avatar
I don't think they measure them the same. DJ has an 800 number you can call and find out for sure. Plus I think I read on here that they are not the same. Good luck!
Shane
