03 Blaster help
Old Feb 10, 2003 | 04:12 PM
Musthavefn's Avatar
Default 03 Blaster help
Just bought a new 03 Blaster Sunday for my son. Does anyone know what the stator wattage output is. Any suggestion on what cheap mods can be done. Is the 230 factory jet ok till I get a pipe.
Any suggestion or comments would be appreciate.
Almost took it back for service because it would not rev up. Some real smart engineer added a stupid don't know what you would call it safety to the parking break. Could not find anything in manual about this. [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Feb 10, 2003 | 09:04 PM
YFZRacer's Avatar
first mods should be a toomey pipe and new tires the stock balloon one sucks then you put the 310 jet in and it halls its like a whole new quad you can also flip the front tires for more stability any more questions ask away hope that helps
-cory
Old Feb 11, 2003 | 02:10 PM
Musthavefn's Avatar
The Toomey sound good. I want to put a 100 watt bulb in the headlight and maybe a 35 watt whip light for running around Glamis at night. Ordered the 21" Gecko paddles for this weekend.
The salesman for what its worth said that there is a restriction washer on the exhaust at the head. I've heard of that on smaller units but thought that would not be the case with a 200. If its there and I remove it will I have to re jet.
Old Feb 11, 2003 | 10:53 PM
raptor8's Avatar
sorry to say, i just went thru the headlite deal. the wattge max is 35 watts!
i put on two small driving lites i found at walmart at 20w each and they work well.
maybe someone like RickyStator makes a larger stator.
before that i tried 2 ea 55w driving lites... no go. i have an o2 and was getting rid of that ugly bar mounted lamp.
good luck finding lamps at 35watts. my next check is a place called radlites, which is engineering groups of LEDs to replace lamps, as they use so much less power. you might check these guys out.... [img]i/expressions/face-icon-small-cool.gif[/img]
Old Feb 11, 2003 | 11:48 PM
YFZRacer's Avatar
ya you can get the stator redone or whatever for more watts but that cost money
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
