gearing a raptor
Old Feb 11, 2003 | 04:46 PM
UBETRUN's Avatar
Default gearing a raptor
I wasn't happy with my Raptor in the woods with stock gearing and REALLY unhappy when I went to 22" rears. Geared way too high (numerically low) to control it in 1st gear in tight trails without slipping the clutch more than I like. I ordered the 12 front and 44 rear at the same time and planned to do the rear first and then the front. I learned quickly that a 44 won't fit on the rear with a 13 up front so I went ahead and changed both at once. FYI, 12/44 is the max for the stock length chain and I wouldn't advise it on a brand new chain, it's really a tight fit. I'm addicted to acceleration and haven't found that I shift too often so I'm going to keep mine at 12/44. A 42 or 43 rear might be better for you if you ride more in the top of 5th.
I may lose a drag race on a very long straight where top speed starts to outweigh acceleration but I won't lose many between here and the next corner:-)
Old Feb 11, 2003 | 07:06 PM
RacinJason's Avatar
Big bubbas gear combos are great with a 20in tireand stock motor(external mods)...with a pumped motor it will pull those stock gears better.
Firefighter400
Oct 8, 2022 06:38 PM
Ashley S
May 29, 2017 10:54 AM
black_thunder
Jul 26, 2015 09:23 PM
black_thunder
Jul 22, 2015 06:01 PM
black_thunder
Jul 9, 2015 05:58 PM
