banshee premix
Old Feb 13, 2003 | 01:08 PM
cak's Avatar
cak
Default banshee premix
for a 2001 banshee how many oz. per gallon should you run?? or ratio wise....
Old Feb 13, 2003 | 01:10 PM
Batoutahell's Avatar
I run 32:1 yamalube 2R
Old Feb 13, 2003 | 01:17 PM
cak's Avatar
cak
alright, what about comp 2 oil?? same ratio??
Old Feb 13, 2003 | 01:26 PM
bansheeguru's Avatar
Yes it should be the same I also run 32:1 ratio but I use Amsoil 2000 I find that yamalube fouls plugs a lot with amsoil I find it doesnt foul the plug nearly as much.
Old Feb 13, 2003 | 01:39 PM
I have been on the same plugs for 7 months and never fouled one.
Bat
Old Feb 13, 2003 | 02:23 PM
RoostItUp's Avatar
You should use MC1, from my experience this is the best oil you can buy imo. I forget what the ratio is but it says on the container.
Old Feb 13, 2003 | 02:58 PM
2fun's Avatar
I use Amsoil 2000 fully synthetic @ 50:1
Burns clean, doesn't gum up, doesn't foul plugs and gives plenty of protection.
Even at 50:1 there was still oil dripping off the crank when I last tore the top-end off of my 250R. Plenty of oil to protect even at this ratio (which is the ratio they recommend).[img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 13, 2003 | 03:00 PM
2fun's Avatar
I would look at what the manufacturer recommends for that oil.
I am unfaniliar with that particular brand, but you can't just go by the same ratio someone else uses.
Also as a general rule, the smaller the CC's, the more oil you want in your gas.
Old Feb 13, 2003 | 03:03 PM
cak's Avatar
cak
so 4oz. per gallon?? and if your fouling plugs, you just need to run it harder...[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 13, 2003 | 03:04 PM
cak's Avatar
cak
thanks but, he has the SAME quad as i do so, it should be fine
