2 stroke oil
I run yamalube at 32:1 since the Banshee was new over 3 years ago. Compression is still great and the cylinders look perfect. I know a guy that runs outboard motor oil in his old late 80's suzuki 250R and it still has the original top-end. Personally, I think all the name brand oils work fine and it would be hard to tell a difference. You gotta figure this stuff goes in, floats around a while in the crankcase and gets blown out pretty quickly so it doesn't need to be long lasting like 4 stroke oils.
Mercury's outboard oil is all I have ever run. Outboard oil is desidned for high RPM heavy load applications (the only motor that is pinned more than my quads is my boat). My builder and the mechanics at the boat dealership that I worked at for years all tell me that the cleanest motors they have ever seen are running outboard oil. I have switched to the new synthetic Merc stuff, but I am not convinced that syn. is the way to go, still working on it.
did any of you guys ever try motul 6t 100% synthetc 2stroke,ive been using it for about 2 years now,and it is good stuff,very low smoke and my sons lt 80 seems to run better.i also run motul e-tech 100%synthetic in my 03 raptor with the k&N oil filter.
anyboby else use this brand of oil
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
