Blaster Timing
Old Feb 14, 2003 | 05:51 PM
Dick123's Avatar
Default Blaster Timing
Does anyone know how to time a Blaster? I had mine rebuilt, and sense I got it back it has run like crap. All of the bottom end seals were changed, so they had everything apart. It ran great up until it blew.
Old Feb 14, 2003 | 06:31 PM
Dick123's Avatar
Nobody?
Old Feb 14, 2003 | 06:47 PM
AlkyBurninX's Avatar
You can't adjust the timing on a blaster.
Old Feb 14, 2003 | 10:57 PM
Peltrax's Avatar
You could get a degree key from vitos to advance timing
Old Feb 15, 2003 | 03:51 PM
TomM's Avatar
If the stator assembly moves you can change the timing. If it doesn’t, you could drill out the screw holes and make them slots. You could then adjust it. If I had a Blaster, I would do it that way rather than spend 25$ for an offset key (degree key). You could also find a key that is too wide and shave the sides to make it offset.
2 of my friends installed a Vito’s degree key at the same time and both melted a piston within 10 hours of riding. I think 4 degrees is too much advance unless you’re building a drag bike. You can’t run it like that for long periods on regular fuel.
Old Feb 15, 2003 | 03:52 PM
TomM's Avatar
They also found that the degree key shears a lot easier than the stock one.[img]i/expressions/face-icon-small-sad.gif[/img]
Frisky2050
Apr 9, 2020 11:19 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
