Torque Specs: Suspension
Old Feb 14, 2003 | 09:51 PM
docdave22's Avatar
Default Torque Specs: Suspension
Got my Alba pro comp arms today, but I don't have a manual yet. Does anyone know the torque specs for these?
A-arm to frame bolts
Ball Joints
Caliper bolts
Banjo bolts for brake lines
Any tips on setting up the camber and toe in/out?
Old Feb 14, 2003 | 10:00 PM
THEMOOSE's Avatar
the bolts on the uppers torque to 27 ft lbs
the lowers are 23 ft lbs
it also says to make sure the bolt heads face outwards on both arms.
Old Feb 14, 2003 | 10:53 PM
docdave22's Avatar
Thanks.
Old Feb 14, 2003 | 11:12 PM
Psycho's Avatar
Manual also says to tighten "union" or "bango" bolts at 19ft. lb.
Ball Joint "castle" nuts @ 18ft. lb.
Hope this helps, doc.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Feb 14, 2003 | 11:15 PM
polarisisthebest's Avatar
Make sure and tell us how you like the pro-comps after you install them, because i am thinking about putting these a arms on my raptor once i get it, but i will also use the works triple rates.
Old Feb 15, 2003 | 11:34 AM
docdave22's Avatar
Cool. Thanks guys.
Fixen to go try them now. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 15, 2003 | 04:36 PM
NotuRaptor2's Avatar
shock bolts are 32 lbs
/NotuRaptor
Old Feb 16, 2003 | 10:27 AM
docdave22's Avatar
Well, I was hoping to go the track today, but it is raining. But I rode around for a couple of hours yesterday and I can tell a big difference in the handling. I am totally confident now at slinging it around without worrying about flipping on the side.
The only cons are
1. $ well made, but come on, and this applies to all brands
2. stock shocks didn't want to fit into the hangers on the lowers. I had to bend the tabs a little
3. steering is stiff as hell now, I am guessing it is because of the new ball joints or the maybe the toe in is wrong
I also really like the braided brake lines. Noticable improvement
dannytas
Sep 26, 2017 06:31 PM
Robinhood
Dec 26, 2015 10:28 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
01ssls1
Sep 22, 2015 06:50 AM
raman8tor
Sep 20, 2015 07:35 AM
