12T or 14T ?
Old Feb 18, 2003 | 07:27 PM
RaptorRy's Avatar
Default 12T or 14T ?
Ordering 22" tires for the Raptor what tooth sproket should I goto dont need any more top end but would like to still have the same acceleration any help would be great oh yeah what brand of sproket should Igo with. Thanks in advance RY
Old Feb 18, 2003 | 07:31 PM
RacinJason's Avatar
I don't think the brand is all to important, I run a 12t counter sprocket with my xct's in the woods to reatain a lower gearing...sprocket specialists
BRAAAAP
Old Feb 18, 2003 | 07:34 PM
RaptorRy's Avatar
Thanks that is what I thought but was not 100% sure.
I was told to buy the better Renthal around $25 so I think that is what I will do.
Old Feb 18, 2003 | 07:35 PM
RaptorCam's Avatar
12 tooth. I have always used Sprocket Specialists brand and never had a problem.
Old Feb 18, 2003 | 08:30 PM
rapdaddy's Avatar
i tried a 14t once.it was way to high.
Old Feb 18, 2003 | 09:01 PM
RoostItUp's Avatar
Try this gearing chart out Gearing
Old Feb 18, 2003 | 09:18 PM
mrbones's Avatar
I have a 12T with 20" tires. Frankly, it still seems geared too high from what I'm used to. I'd like to put a larger sprocket on the back as well, but it would hit the skid plate. I've never ran the 14T since mine came with a 12T. I'll stick with it.
Old Feb 19, 2003 | 06:33 PM
raptor03's Avatar
well i put a 12 tooth on mine and it did run faster at dumont ,not sure about glamis or the desert,but i did feel a little gear changes were sketchy because the chain was under pressure,but it lasted a weekend with no problems,did hear a little squeek in the sprocket but i think it was the sand ,cleaned it today and it sounds good,the 12 tooth did what i wanted it to,and i beat most bikes up the hill with the same mods as me..
