Banshee running on one cylinder!!
Old Feb 19, 2003 | 11:21 AM
bansheeguru's Avatar
Default Banshee running on one cylinder!!
I agree with BartlettRacing Check compression before you start randomly replacing parts.
Old Feb 19, 2003 | 11:23 AM
Also check to see if the hose between both carbs is there ant isnt leaking.
Old Feb 19, 2003 | 11:29 AM
garyc660R's Avatar
Originally posted by: WyoDuner
Yep, it almost has to be either a bad reed or the carbs are out of sync. Should be easy to fix.
SO, the cylinder is down because no fuel is being introduced? Sounds pretty DRY.
Old Feb 19, 2003 | 11:59 AM
Ernie660R's Avatar
You are right AlkyBurniX, it is the left cylinder. I will check the carbs first this weekend first. Thanks guys for all of your input.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 19, 2003 | 12:58 PM
  #15
WyoDuner's Avatar
Well, I guess you are saying that if there's no fuel/oil the cylinder is not getting lubricated. That's correct. Of course that could lead to a worn cylinder and low compression. Still I'm guessing carbs need synced or damaged reed.
Old Feb 19, 2003 | 02:52 PM
  #16
2002bansheeman350's Avatar
take out your air filter and look into your air box. check if one of your carborator valves are open
this happend to me the other day but it was real easy to push in the throttle
for me dropped down by itself couse i left it alone /the second time it happend it droped back down a lot qicker and ran fin after that
maybe yours is stuck real good idk check it out though
if it is open then the bike will only run on 1 cylender
kevin
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
scaldwellk
Jun 19, 2015 05:08 PM
Dabears1983
Jun 16, 2015 12:17 PM
Timjunior
Ask the Editor
May 28, 2015 01:09 PM
B4NSH333
May 26, 2015 06:55 AM
