? compression on Stock Shee
Old Feb 24, 2003 | 09:42 PM
Banshee2001BW's Avatar
Default ? compression on Stock Shee
I was wondering what the compression (PSI) was of a stock Shee. I low can you go before having any problems. Any feedback would be appreciated.
REG
2001 B&W Shee
FMF Gnarly
Boost Bottle
Factory effex Sticker and seat cover
Razor Tires:
Old Feb 24, 2003 | 11:20 PM
miniblaster's Avatar
when you get around 110 or so it's time to rebuild. i think they also say if you have like a 20% difference between the cylinders you need to rebuild also. other than that your good to go
mini
Old Feb 24, 2003 | 11:32 PM
Batoutahell's Avatar
well it depends on your altitude, a brand new banshee here at 6400ft will only have about 95 psi. With 18cc domes, I get 135-140.
It is good to get a baseline, then you can tell when it starts to drop. That is what I did with mine. the 20% thing is a good rule of thumb also.
Hard starting can be a symptom of low compression, you could ask some shops around your area what kind of psi they get.
Bat
Old Feb 24, 2003 | 11:34 PM
YFZRacer's Avatar
i'm not very educated in this how do you check the compression is there some sort of gauge you buy?
Old Feb 25, 2003 | 12:02 AM
yea, it is a thing that screws down into your cylinder(spark plug hole) and when you roll it over, it guages your commpression. at least that is the way the one i saw worked
mini
Old Feb 25, 2003 | 12:03 AM
YFZRacer's Avatar
ic thanks
Old Feb 25, 2003 | 01:27 AM
2fun's Avatar
There is a small writeup on compression testers in the Honda forum.
Old Feb 25, 2003 | 01:29 AM
YFZRacer's Avatar
where do you have a link?
Customer Service #1
May 15, 2020 08:46 AM
QuadRiders
Oct 22, 2015 04:13 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
