warrior WB e-series owners
Old Feb 28, 2003 | 09:17 PM
kuz28's Avatar
Default warrior WB e-series owners
I need to know what you used for jetting with your e-series pipe. I got a pro-flo filter and the motoforce lid. I know this is a common combo so im hoping you can help.
Old Feb 28, 2003 | 09:30 PM
FISHER1648's Avatar
#147 - at 4500 ft. and #150 at sea level.
My airbox lid has about a 4"X6" hole cut in it with an outerwears panel over it. Seems it's a bit fat at sea level but "it aint burned up yet" so I know it's on the safe side.
Old Mar 1, 2003 | 02:23 AM
Blaster96's Avatar
I run a 145 with all 12 disk's not quite core, and a UNI filer with the needel clip one spot down from the top at about 1,200 (or how ever high KS is). When ever i head to colorado it set it at 137.5 and the needle at the Top, elevations there are from 7,000-14,000. I have the full airbox cover also.
Old Mar 1, 2003 | 04:40 PM
1BadWarrior's Avatar
I have my Warrior jetted with Dynojets and I think I am running a 135 main jet. Not sure about the clip but stock pilot jet. I have a K&N air filter and 4 one inch holes in my airbox lid. My Warrior seems to run pretty good it may be a little on the rich side. My question is what do you guys have your mixture screw set at I think mine is at 3 1/2 and I believe thats wrong.
Old Mar 1, 2003 | 09:45 PM
Dunescreaminmama's Avatar
I run DJ 144 main, needle clipped at 3rd, 12 plates, Pro Flow, air box looks like I took a .12 gauge to it, and air/fuel screw at 2.25. I ride at around 3,000 to 5,000 feet and it has been around 40 degrees out. Seems to be strong, snappy, no bogs.
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Ahtatu
Sep 28, 2015 12:14 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
