TIRES/SPROCKETS
Old Mar 3, 2003 | 02:12 AM
YamahaRaptor660R's Avatar
Default TIRES/SPROCKETS
ok im goin up to a 22inch tire and dont want to loose any acceleration as i do mostly trail riding and some slow riding so would goin down to a 12 t in the front be enough to compensate for larger tires?
any suggestions
also what are some good mud / snow tires for the raptor
i still want to be able to slide and cut donuts but also make it through creek crossings and some muddy areas
i was thinkin either dirt devils, spder tracs, super swampers, bearclaws, gators
any suggestions will be much appreciated
Old Mar 3, 2003 | 11:48 AM
UBETRUN's Avatar
How about the ITP 489s? The Kenda Bearclaws look tough also.
I don't know how it would run in the woods with 12/40 but I'm real happy with my gearing/grunt ratio.12/44 is more than enough to get back lost oomph with 22" tires but 12/43 would be easier to install:-)
Old Mar 3, 2003 | 12:16 PM
garyc660R's Avatar
I went from 14/40 gearing too 13/43 when I went up too a more trail worthy 22" tall tire. Thats a big change, but thats what it took too get the acceleration back. I went with Shredders....they don't slide real well....but hookup is unbelievable. I would recommend the dirt devils...the hook and slide.
Old Mar 4, 2003 | 01:01 AM
the stock gearing is either 14 or 13 on front and a 40 on back would goin up to a 41 or 42 be enough i dont wanna loose any top end if i can help it
also can i fit a 41 or 42 sprocket on back with the stock skidplate on therE? i noticed today that my chain is rubbing skidplate now so can i shim my skidplate down a little for more clearance for sprockets or what should i do ride around too many rocks to leave it off
was also considering gmudsharks or pure sports REALTOR (mean lookin tires)
Old Mar 4, 2003 | 05:37 PM
btt
Old Mar 4, 2003 | 05:40 PM
decided to go 12 40 on gearin because 1 t smaller on front is equal to 3 bigger on back so i should be at the same ratio as Gary now tires and sprocket will be in friday
Old Mar 5, 2003 | 01:05 AM
any suggestions?
also anyone have any stock rear raptor rims they would care to sell fairly cheap dont like the 200$ price tag on new ones
and i dont wanna have to buy 4 all new rims just need xtra set for back one for trail tires and one for track tires
Old Mar 5, 2003 | 08:52 AM
garyc660R's Avatar
You could have got the tire - rim combo from www.rockymountainatv.com reasonable. If you get aftermarket rims, I would go-ahead and get 1" offsets for a slightly wider stance...should be perfect for trails. If the sprocket does'nt come in....contact me, I have a slightly used one you can have.
Old Mar 5, 2003 | 05:07 PM
ya i thought about that but you cant get aftermarket rims IDENTICAL to stockers can you?
didnt wanna have to buy for new ones for matchin set
Old Mar 5, 2003 | 05:12 PM
garyc660R's Avatar
Unless someone is looking for different wheels, they probably won't notice a difference in the wheels anyway. The rolled edge is pretty much identical...but they are pricey. Are you gonna ride it or show it...lol. Just joking bro.
