Adjusting the valves?????
Old Mar 3, 2003 | 10:14 PM
Nordy's Avatar
Default Adjusting the valves?????
I just adjusted the valves on my raptor. The only hard part was to adjust the exhaust valves they are really hard to get a good feel with the feeler guages. I think I did it right I don't hear anything clattering and they are not too tight. The only thing I've noticed is that the pipe sounds wierd now. Its a stock pipe. Any of you ever experience this???? I talked with a dealer mechanic today he seemed to think as long as it wasn't too tight or to loose it should be fine. just thought I'd ask. Thanks
Old Mar 3, 2003 | 11:03 PM
RhondaV's Avatar
Did you make sure that you tightened up the head pipe bolts? You may have a leak if they aren't seated all the way. Did you make sure that one of the header gaskets didn't fall out causing an exhaust leak.
Old Mar 3, 2003 | 11:12 PM
Nordy's Avatar
I didn't do anything with the header. I think it will be fine I might check it in a little bit they are easy to get to without removing everything so I'll keep an ear on the noise.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
