Raptor vs. ???
Old Mar 9, 2003 | 04:38 PM
  #21
GYTR's Avatar
Default Raptor vs. ???
Only complaint i have is the rev limiter in reverse but i will be taking care of that in a few days
Old Mar 9, 2003 | 05:54 PM
  #22
ravencr's Avatar
How do you take care of that? Is there a rev limiter in forward?
Old Mar 9, 2003 | 10:30 PM
  #23
GYTR's Avatar
you ground out this one wire.there is one in forward but you dont have to worry about that one. the one in reverse is worthless thats why you ground it out to full rpms to get unstuck or what ever
Old Mar 9, 2003 | 10:47 PM
  #24
ravencr's Avatar
I've heard that there is a chip or something that will allow the raptor to go from it's stock RPM limit to a much higher limit. Is this true? If not, why wouldn't you want to also remove the forward RPM limiter. It seems to me that you could get more power. Could it be that it's bad for the motor?
Chris
Old Mar 9, 2003 | 10:52 PM
  #25
RSO660R's Avatar
More rpm`s on your stock vavle train =more wear not necessarily more power.
Remember the Raptor motor is not a 2 smoke so it makes most of its power down low
Old Mar 9, 2003 | 10:57 PM
  #26
ravencr's Avatar
That's what I like. Is anyone using wheel spacers front and rear instead of buying wider rear axle and wider a-arms? Are there any downfalls to doing this. I know it's a lot cheaper!
Chris
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
