guys please jetting problem !
Old Mar 11, 2003 | 11:22 AM
  #31
Batoutahell's Avatar
Default guys please jetting problem !
good info from 2fun, I would only reccommend that you dont do a full throttle run until you change that main up a few. I just dont want to see a burnt up engine.
The big screws on top of the carbs are to adjust the idle speed and sync the carbs. Which by the way have you checked. they carbs need to open and close at the same time.
I agree with doing plug checks, but I think you are too lean on top to do a full throttle check.
get a manual, then bump the mains up, then make sure the carbs are synced, then do some plug checks and adjust from there.
2fun gave you the proper method, you need to follow that. I would thank him for typing all that in.
Let us know how it all comes out in the end.
Bat
Old Mar 11, 2003 | 01:47 PM
  #32
2fun's Avatar
Thanks Bat.
I agree he should bump up the mains before doing the plug check.
Even if he didn't bump them up first, he shouldn't burn the motor up on a 10-15 second run. Even so, with the mods he listed at sea level, I agree he is probably running lean.
Better to be safe than sorry.
Old Mar 12, 2003 | 12:23 AM
  #33
cOoLdevil's Avatar
thanx to both of you 2fun and Batoutahell for the good info im going to change the needle clip to #3 and the biger mains and i will do the plug check and i hope to get it right this time [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 12, 2003 | 12:51 AM
  #34
No problem, your welcome, just out of curiousity let us know how it comes out and what jetting you end up with.
I like to have ballparks for when I travel around.
Thanks
Bat
Old Mar 12, 2003 | 12:55 AM
  #35
cOoLdevil's Avatar
oh yah you will know . when im done with this thing i will post the result
Old Mar 12, 2003 | 01:08 AM
  #36
2fun's Avatar
You are welcome.[img]i/expressions/face-icon-small-wink.gif[/img]
Just be sure to follow the procedure, and use fresh properly gapped sparkplugs.[img]i/expressions/face-icon-small-wink.gif[/img]
And yes, please do let us know what you end up going with.
Feedback = good[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 12, 2003 | 03:08 AM
  #37
cOoLdevil's Avatar
ok i will follow the procedure thats great instraction thank you guys very much
Old Mar 12, 2003 | 03:12 AM
  #38
cOoLdevil's Avatar
one more thing what do you think of the HD clutch springs 50/50 ?
Old Mar 14, 2003 | 07:31 PM
  #39
2fun's Avatar
Not sure what you are talking about there.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 15, 2003 | 01:23 AM
  #40
cOoLdevil's Avatar
im talking a bout stifer clutch springs should i install all 6 of them or only 3 50/50
