Stressed out!!
Old Mar 16, 2003 | 05:13 PM
Dick123's Avatar
Default Stressed out!!
This is making me pretty madd. I had my blaster rebuilt and it hasn't ran right sense. I have spent months twisting screws and changing jets. There has to be some way adjust when it sparks, because it is off. I went way down in the jet size and it is still very very rich. Something was changed when the bottom end was taken apart or something, but it is really making me mad. I know if I sell it i wont get crap out of it cuz it runs like crap, even though it was just rebuilt. If I take it in, they will rape me as usual, and that is going to happen. Does anyone have any suggestions? Ever had any problem like this?
Old Mar 16, 2003 | 05:45 PM
NEMISIS's Avatar
check the compression.
Old Mar 16, 2003 | 07:25 PM
Dick123's Avatar
i will check, but what would be the reason for it being rich?
Old Mar 16, 2003 | 08:24 PM
Ward660R's Avatar
What was rebuilt? You said bottom end so the whole thing or what? You shouldn't be ANY more rich just from a rebuild, if anything maybe a little lean. What else changed? Are you sure your not sucking in air from somewhere?
Old Mar 17, 2003 | 08:44 PM
Dick123's Avatar
The bottom was checked, and seals were replaced. The top was rebuilt. I cant think of anything I have changed, just pulled it, left it set and put it back together.
Old Mar 17, 2003 | 09:06 PM
JakalWarrior's Avatar
Did you use a thinner headgasket to raise the compression or something? raising the compression can make an engine a little richer.
Old Mar 17, 2003 | 09:08 PM
Dick123's Avatar
I dont think so man, I just told the guys at the shop, I was rebuilding a blaster, and they had the gaskets in stock, so I asume they are the same?
Old Mar 17, 2003 | 09:49 PM
BADBRONCO's Avatar
Have you checked the timing?
Old Mar 17, 2003 | 09:52 PM
Dick123's Avatar
THATS WHAT I LIKE TO HEAR! I have been asking about that, but everyone says u cant time them. How do you change the timing? I have a guy that will lend me the light, but how do you change it if it is off?
Old Mar 18, 2003 | 09:40 PM
Dick123's Avatar
Come on, someone has to know!
