engine coolant
Old Mar 25, 2003 | 04:31 PM
whitebread's Avatar
Default engine coolant
i've looked all over for engine ice for the raptor and can't seem to find it.
has anybody tried this stuff out?
coolant addative
it says its for use on all vehicles,streetrods,sportutility,and industrial equipment with gas or diesel engines.
benefits:lower temp
reduces rust and corrosion
stops leaks
cleans cooling system
removes scale deposits
dramatically increases heat transfer
contains no antifreeze.
it also says do not add antifreeze with this and water.
Old Mar 25, 2003 | 04:36 PM
whitebread's Avatar
heres a link to the people that make it.pro blend motorsports
Old Mar 25, 2003 | 04:40 PM
Nordy's Avatar
try rocky mountain atv they might have it.
Old Mar 25, 2003 | 04:42 PM
BigBadScrambler's Avatar
I just started using Purple Ice So far I like it. It is cheap and available anywhere Royal Purple products are sold. Plus it only takes 1 ounce per quart of coolant.
Old Mar 26, 2003 | 12:47 AM
AlkyBurninX's Avatar
Redline makes Water Wetter. It just mixes with your current coolant. FTZ swears by it, but I prefer to run Engine Ice. It is ran straight and works great.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
SDR-II
Sep 29, 2015 01:06 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Coryco
Jul 6, 2015 07:30 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
