blaster 2003
Old Mar 30, 2003 | 01:08 AM
blaster2003kdk's Avatar
Default blaster 2003
can someone tell me what size tires i should get an what kinda wheel for my 2003 blaster.
Old Mar 30, 2003 | 06:06 PM
Textcan someone please help me wit what tires i should get for my blaster
Old Mar 30, 2003 | 06:36 PM
YFZRacer's Avatar
what conditions do you ride in
if its dirt trails either holeshots or razrs are good or if you want a little cheaper but still a good tire fast treckers would work and a 20inch tire is what you want to have hoep that helps
Old Mar 30, 2003 | 06:41 PM
so 20 inch rimes do u think razors would be the best deal
Old Mar 30, 2003 | 06:43 PM
YFZRacer's Avatar
i think you might be a little confused
when i say 20inch that is the rubber part or the tire
a wheel is the inside part of the story that can be chrome or steel they are usually about 9 inches or so
just to clarify it...hope you understand that
Old Mar 30, 2003 | 06:46 PM
yeah 9inch rime .ouestion i got a procurcuit pipe on my blaster what jet size would u say to put in it.iam new at this
Old Mar 30, 2003 | 07:13 PM
YFZRacer's Avatar
hey no problem i'm not expert either
in my toomey kit i have a 310 its always better to be rich then lean so i would start at about a 300 and work your way down till your plugs a nice tan color
-cory
Old Mar 30, 2003 | 07:15 PM
all i got in mine is a 260 that the biggest one they gave me.
Old Mar 30, 2003 | 07:18 PM
YFZRacer's Avatar
does it seem to run lean or ok i guess that could be the correct jetting it also depends on atitute the higher you are the bigger or fatter the jet you need what do the spark plugs look like if there white its lean which isn't good for the motor if there black or dark brown you are rich you want a tan color
Old Mar 30, 2003 | 07:21 PM
what do u mean by lean.i havent changed the spark plug since i had itquestion does your first an second gear go by guick
