Offset ?
Old Mar 30, 2003 | 09:07 PM
OCTANE's Avatar
Default Offset ?
I bent up my stock rims and am going to need some new rear rims. I have made up my mind and am going with just the original douglas .190. My question is I want to get the rims with an offset that will make my quad 2 inches wider on each side for a total of 4 inches. But I have no idea how offset works can somebody please point me in the right direction, thanks.
Old Mar 30, 2003 | 10:04 PM
sixsixT's Avatar
Default Offset ?
I think your rims would bend to easy if you offset the rears that much.Check out the douglas web site it has some info that might help you.
Old Mar 30, 2003 | 11:14 PM
Hossblur's Avatar
Default Offset ?
COntact Debi (contacts e-mail) at rocky mountain atv- she explained it to me, I stayed away from the offsets, personal pref.
Old Apr 1, 2003 | 02:14 AM
RaptorRacer1's Avatar
Default Offset ?
I have run ITP wheels with 1" more offset on each side for over a year now with no problems. No bends, no flats. I don't know if anyone makes one with 2" extra offset per side.
When an offset is listed, it will have 2 numbers for example, for a front Raptor rim
10x5, +2+3
That is a 10"diameter, 5 inch wide rim. It will be 2 inches from the inside of the OUTER bead to the mounting surface, and 3 inches from the inside of the INNER bead to the mounting surface.
Just call ITP and they will be able to answer/explain any more questions you may have.
RR1
badgerboy1
Sep 26, 2017 06:11 PM
Jason Campbell
Sep 7, 2015 02:25 PM
YAMAN
Jun 9, 2001 12:35 PM
xtreme165
Jan 24, 2001 11:20 PM
skull
Dec 28, 2000 10:53 AM
