WARRIOR GURU'S
Old Apr 11, 2003 | 04:03 AM
mellowWETTO's Avatar
Default WARRIOR GURU'S
I bought the pro design pro-flow (k&n) for a 2001 warrior from rocky mountain atv. I installed the adapter correctly but I cannot bolt on the airbox lid because of the filter. I called rocky mountain atv & they said that I had the correct air filter. The filter they sent is 4 1/2" in diameter & 5" long. Any warrior guys with the pro design pro flow kit let me know the size of your air filter & any jetting advice would be cool also. Thanx!!!
Old Apr 11, 2003 | 09:20 AM
JakalWarrior's Avatar
My lid wont go on either because of the angle the filter is at. Try rotating it around till you get it where the lid will fit. My filter is a: RU-1460, whatever that means. No size given on box.
Old Apr 11, 2003 | 03:22 PM
My filter # is RB-0910. I have tried everything to get the lid to fit.
Old Apr 11, 2003 | 08:10 PM
Fendercover's Avatar
I've got the Uni filter with my pro design , fits fine without the prefilter on, but once you install it you really have to cram on the lid. I imagine that your k&n is the same way.
Old Apr 11, 2003 | 08:49 PM
Not much point in a K&N if you leave the lid on anywho.
Old Apr 11, 2003 | 10:05 PM
True.
Old Apr 11, 2003 | 10:23 PM
gotmudd's Avatar
I had the same problem with my k&n set up, once on a long hard ride when i got back i decided to check and clean the filter. To my surprise when i took the lid off the filter fell off. Going back to stock setup with a better filter.
Old Apr 13, 2003 | 02:46 AM
Since I'm using a K&N should I leave the lid on or off. Any input on jetting would help. I have an aftermarket pipe and ride at 1000-1100 ft. Thanx for everyones 2 pennies.
Old Apr 15, 2003 | 05:52 PM
fitoo's Avatar
leave the lid off and put an outerwear on it! What pipe do you have? Better yet come over and we'll get it jetted correct!
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
