help!! how do I tighten my blaster shock????
Old Apr 13, 2003 | 11:51 PM
teoamaru's Avatar
Default help!! how do I tighten my blaster shock????
Hey guys, I was wondering if someone could help me out with this. I need to know how to tighten a blaster shock, I'm racing and I really have to tighten it up. I have a 2000. Any help would be greatly appreciated. Thanks again all!!!!!!!!!!!!
Old Apr 15, 2003 | 12:59 AM
DunePilot858's Avatar
What do you mean tighten it up? Are you bottoming out or does the quad sit low in the back with you sitting on it? Your going to have to explain your situation a little more for people to help you out. I'll say one thing though... if you are bottoming out badly your not going to fix it with that stock shock. You will have to look at aftermarket solutions that are taylored around your weight and riding style/ability.
Old Apr 22, 2003 | 05:47 PM
BLASTERDEVIL2's Avatar
jack the back tires off the ground. there is 2 nuts on the lower side of the spring. tighten the top one up to where you want it and the re tighten the locking nut. take it out and give it a try. if it feel s to tight loosen it back down some. if it still to loose tighten it out some more. but if it is still too loose you will probably need a new shock.
Ahtatu
Sep 28, 2015 12:14 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
nastyblaster100
Sep 13, 2015 01:19 PM
