Raptor bore
Old Apr 22, 2003 | 09:01 PM
white660Raptor's Avatar
Default Raptor bore
I want a bore kit for my raptor but i still want to trail ride and don't want to run race fuel through it. All the kits I see are running a 11:1 or higher compression and i was told you need to run anything higher than 10:1 on race fuel. Any suggestions.
Old Apr 22, 2003 | 09:14 PM
sixsixT's Avatar
Default Raptor bore
It should be fine on premo but a little mix 25% might not hurt.
Old Apr 22, 2003 | 10:00 PM
XtremeRaptor's Avatar
Default Raptor bore
Mine is running fine on Premium unleaded.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 22, 2003 | 10:09 PM
Default Raptor bore
xtremeraptor what are you running for a compression ratio.
Old Apr 22, 2003 | 10:15 PM
RacinJason's Avatar
Default Raptor bore
stay 11 to 1 or lower for saftey
Old Apr 22, 2003 | 10:22 PM
RepTaR660r's Avatar
Default Raptor bore
I hate paying 4 dollars + a gallon for gas...
Not to mention 3.50 for a quart of 2 stoke oil...
Old Apr 22, 2003 | 10:43 PM
Default Raptor bore
Yeah i feel the same way reptar660r. And thanks for your input everyone.
Old Apr 22, 2003 | 10:49 PM
RaptorRidr660R's Avatar
Default Raptor bore
I had a DRZ and that was 12.2 to 1 compression and it ran awsome on 92 pump gas. I don't think you would have the need for race fuel.
Old Apr 23, 2003 | 03:47 AM
14mins's Avatar
Default Raptor bore
11-1 will run on super unleaded (92 octane) most of the time but not 100 percent of the time.
air- I think you out to check your TRUE compression and not go by what you were told. I will give you a little credit on head pipe size, the stock size is good for 99.5 percent of the people
Old Apr 23, 2003 | 12:09 PM
ba01raptoraz's Avatar
Default Raptor bore
So what does it take for the other 0.5% of the people to need to get the larger diameter headpipe? Cause I was thinking of ordering the MBRP race head pipe and having it ceramic coated inside and out.
