Question for sixsixt (jetting and floats)
Well I finally got around to adjusting the floats and that was my problem for sure! They were pretty far off actually, I adjusted them to as close to 1/8" as I could get and took it for a test spin. It solved the wheelie problem and the low end hessitation issue. The plug was black after a plug check before, now it is a nice tan/brown color. I didn't touch the screws at all, so they are still at 2 1/4 and 2 3/4. Thanks again for your help guys!
#16
#18
My brand new, one-day old Raptor is pouring fuel from right carb overflow. Must be a stuck float. I'm gonna pull the carbs and adjust the floats. Above, it says, " I didn't touch the screws at all, so they are still at 2 1/4 and 2 3/4." Which screws are you referring to? One is 2 1/4 and the other is 2 3/4. Is there any way to describe which screw is which? Thanks!!!!!
#19
