wolverine missing?
When you take off the plug start the wolverine up it should spit and sputter, then hold in the the silver **** that disengages the spitting and sputtering. Usually I have to take wd-40 or some kind of water lubricate and apply it to the little silver ****. if this works with the plug out check the emergency **** that pulls the handle back and make sure there isn't mud or any foriegn objects keeping it for going all the way in.
#15
bighunter
#16
bighunter, That is what could be the problem. It you look at your left hand brake perch there is a thing connected to the back that has wire going into it. That is the override switch for the e-brake. Take it out and make sure the silver ****, which is the switch is working properly. Some people had to cut the wires but I am not for sure if you have to tie them back in some where or if you can just cut them off and tape them up.
