Rappy Shift Levers
Old May 5, 2003 | 06:58 PM
fizzak's Avatar
Default Rappy Shift Levers
I just put on some AC nerfs and rode for a while. Since they bolt up in front of the stock pegs, I didn't realize how much less room there is now between the stock peg and the shift lever. Which aftermarket lever is longer?
Also, I noticed the Roll Design Lever does not have the linkage. I can't imagine it working with my high stock pegs.
Old May 5, 2003 | 08:00 PM
tanstaafl's Avatar
correct. and it works fine with the stock pegs. Though, i must admit..i liked it so much i decided to get their race pegs and brake lever setup......
Old May 5, 2003 | 09:04 PM
fizzak's Avatar
Originally posted by: Ridley
The roll design simply eliminates the weak linkage. It works great with stock or lowered pegs. I asume you know you can raise or lower the shifter, stock or linkageless, by just moving it on the splines???
Yea, I did adjust by moving the spline, up 2 or 3 notches. I can now barely get my boot in there but now I have to lift my leg up and over to downshift. I wish the stock lever was just 1 inch longer.
Old May 5, 2003 | 09:46 PM
ChubbyNug's Avatar
Don't put the nets so tight on the left side where the shifter is, I loosened it up to where my foot fits perfectly under the shifter and that solved all of my problems!!
NuG
Old May 6, 2003 | 08:41 AM
garyc660R's Avatar
Originally posted by: fizzak
Q]Yea, I did adjust by moving the spline, up 2 or 3 notches. I can now barely get my boot in there but now I have to lift my leg up and over to downshift. I wish the stock lever was just 1 inch longer.
So now you have the shifter so low that you don't have too raise your foot too gear down? Probably not a good idea for the shifter too rest below the peg.....eventually, it will get drug off. Just a heads up bro!
95wolv
Sep 27, 2024 12:00 PM
EIF
Apr 20, 2017 07:15 PM
tysonbully
Sep 28, 2015 02:30 AM
Clint Russell
Sep 25, 2015 03:20 PM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
