Warrior slipping out of gear
Old May 11, 2003 | 10:32 PM
XxDumontRaptorxX's Avatar
Default Warrior slipping out of gear
My warrior has a problem with slipping out of second gear, and catching 3rd gear. for some reason it always falls into nuetral when you are shifting while climbing a hill or pulling a load, and feedback?
Old May 12, 2003 | 12:44 AM
Mr45auto's Avatar
Simple solution. Maintain pressure on the shifter whether up or down while releasing the clutch. You will feel the shifter slide a bit further as the clutch is released and it will positively lock in gear. It takes practice but will END your trouble.
Old May 12, 2003 | 11:39 AM
KGB's Avatar
KGB
I had the same problems with my 2000 warrior, my buddies both did too. I tried what mr 45auto siad, and I raised the shifter to help with the problem. No dice. It was only a problem for me on bigger hills where you had alot of load on the tranny. I ended up haveing my girlfriend almost get the damn thing to turn over on her up a big sand hill. It was sold on the following monday, replaced with her z400. Same story with both of my buddies.
Old May 12, 2003 | 12:27 PM
LOWBOWTIE's Avatar
Sorry I had the same problem with my girlfriends warrior. Couldn't get it to stop jumping out of gear on steep sand hills. Trust me if you add 11:1 piston and a big cam w/titanium vavle springs the new power destroys the trans.[img]i/expressions/face-icon-small-sad.gif[/img] Just speeking from my luck[img]i/expressions/face-icon-small-wink.gif[/img]
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Reactant
Jul 27, 2015 07:45 PM
Reactant
Jul 16, 2015 10:29 PM
