2) Chassis problems.. If your quad runs but you have other problems.. post in here.
dinli 90cc just clicks when push electric start button
Old 04-11-2016, 08:04 PM
R.J.'s Avatar
Default dinli 90cc just clicks when push electric start button
I have a dinli 90cc 2stroke quad it runs great when I use the kick start . I installed a new battery today for the electric start and when I push the button I hear one click then nothing push it again and one click . ran out of time to work on it tonight so I thought I would ask what your thoughts are??
Old 04-11-2016, 08:08 PM
Ain't too familar with these,but similar to Polaris youth models. Have you checked to see if power is reaching the starter? If not,could be a relay? Just throwing it out there. Others may be able to tell you what's wrong if that's not it.Starter Relay Solenoid for Dinli 50cc 90cc 110cc Dino Beast Diamond Back ATV New | eBay
Old 04-11-2016, 08:15 PM
R.J.'s Avatar
no I didn't get a chance to check if there is power at starter. I checked the inline fuse and that was good . it sat for awhile before I bought it so hopefully tomorrow I can make it out to garage and check for power and or dirty connections .
Old 04-12-2016, 07:04 AM
LT80's Avatar
LT80 Expert
I agree with OPT, prolly the relay.
Old 04-12-2016, 07:39 AM
R.J.'s Avatar
thanks guys I will try to get out and check the connections and power today and let you know what I come up with
Old 04-12-2016, 02:33 PM
R.J.'s Avatar
ok guys went out to garage today and tinkered on the quad. when I push the electric start button it clicks once and there is 12.79 volts at the starter , I removed the starter and hooked it up direct to battery and it does nothing so I'm pretty sure the starter is shot
Old 04-12-2016, 02:47 PM
Looks similar to Polaris youth model starters. Have em here pretty cheap. At least cheaper than I've found on ebay.Chinese Starter 2-Stroke 90cc Engine Version 26 - Dinli | VMC Chinese Parts
Old 04-12-2016, 03:01 PM
R.J.'s Avatar
thanks, that's about 15 dollars cheaper than ebay . when it comes I will install it and let you guys know the results that should be the last of the unknown on the quad now lol
Old 04-12-2016, 03:11 PM
There's always the unknown factors on these little Chinese and Taiwanese atvs no matter what brand.. Good luck..
Old 04-12-2016, 04:17 PM
R.J.'s Avatar
I agree no matter what your tinkering on everything needs fixing sooner or later...overall this one hasn't been too bad just needed a little more than the seller said it did
Quick Reply: dinli 90cc just clicks when push electric start button
