2002 375 , 2wd auto , where is coolant fill ???
Old 05-14-2009, 06:44 PM
toolhawk's Avatar
Default 2002 375 , 2wd auto , where is coolant fill ???
how do I check the coolant level , 2002 ,375, am I blind!!!, Thanks
Old 05-14-2009, 08:36 PM
mudslinginfool's Avatar
Does it in the Mud!
i may be wrong,but i think that in 2002 they stopped with liquid cooled engines on that model and put in an oil cooler(alot smaller in size compared to a regular radiator). This may or may not have a fan but it would be an oil cooler only if my memory is correct, so dont quote me on this. Also, if it is liquid cooled, the radiator cap is under the front plastic. You will see a small, square, piece in the center of your rack that looks like it comes off. Well It does and thats where you fill it.
Old 05-14-2009, 10:08 PM
upnort's Avatar
My friend has a 375 and it is air cooled oil with a heat exchanger.
Old 05-15-2009, 09:21 AM
TLC's Avatar
TLC
TLC is offline
You will be looking for a long time for a rad on that ATV.
http://www.powersportsnetwork.com/en...hicleCode=3215
Old 05-15-2009, 12:34 PM
swampyjunior's Avatar
Upon looking in the parts micro fiche Ihave and the service manual both show the 2002 375 as being oil cooled. Although there could be a plastic hole under the front rack that one would think access a radiator. (it does on the 500 which has the same plastics)
So good news, You are NOT blind! Bad news is if you were wondering this becasue the engine seems to run hot, you feel the heat on your leg near the exhaust, that is normal for this machine.
Welcome to the forum,
SJ
95wolv
03-09-2020 03:25 AM
Alex G.
09-11-2017 11:38 PM
Clint Russell
09-25-2015 03:20 PM
wrencher82
09-24-2015 03:39 PM
Quick Reply: 2002 375 , 2wd auto , where is coolant fill ???
