brake bleeding
when i replaced the M/C on my 300 i had the same problem. this is what i did. get some clear plastic tubing that fits the bleeder screw tightly. get a clean coke bottle,put some clean brake fluid in it. put the open end of the tubing in the bottle open the bleeder screw and slowly but smoothly pump the brake lever untill you no longer see bubbles in the fluid that is in the bottle.do this at each caliper. as mentioned above start with the caliper farthest from the M/C. when finished, remove the M/C lid,crack open the line at the M/C and let it drip for a minute or so, keeping the reservoir full. any air left in the system will travel to the top.
oliveiracarlos
09-07-2015 03:39 AM
