98 BearCat 454 Water Pump Problem
Old 12-07-2011, 12:32 PM
NH-ATV's Avatar
Default 98 BearCat 454 Water Pump Problem
So the little drain between the seals is leaking. I order the seals, and new impeller and read the book on this "fun" repair. Project seem a pain but straight forward. However... anybody run into this problem?
I get the bolt (washer and seal) out of the impeller "freeing" it from the shaft. But the impeller wont budge. I try a little nudge with a screw driver, nothing. The fingers on my small wheel/gear puller are too big (on .150) to get behind the impeller to pull it off.
Any suggestions?
Old 12-22-2011, 04:01 PM
Williebee's Avatar
Post 98 BearCat 454 Water Pump Problem
Any suggestions?
I have a special puller that i bought when i was running my Small Engine Repair Shop , i don't remember whom i purchased it from , auto repair store or from my parts distributor , but it has 1/4 " leg's to get into tight spot's ; if you haven't gotten the impeller off yet you can take it to your local Small Engine Repair Shop / Lawn And Garden they should be able to get it off without damaging the impeller shaft ( Be very careful pulling impeller ) my cousin broke the shaft on his 1989 Kawasaki Mohave 250 trying to remove his !
He chewed up 3 gear's in his tranny and tried doing the repair himself , by the time he brought it to me i had to tap and rethread the shaft ; hope this is of some help to you .
williebee...........
Nondem
02-22-2020 12:20 PM
KimSJoh
14
07-18-2015 07:20 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
07-08-2015 02:16 PM
Robbbb55
07-08-2015 02:11 PM
Mikea1978
07-04-2015 12:37 PM
Quick Reply: 98 BearCat 454 Water Pump Problem
