oil leak
Old 02-01-2015, 07:40 AM
joust's Avatar
Default oil leak
i have a trv 1000 2009 and yesterday some oil started to leak from the valve drain of the air filter?anyone know what it is?thanks justin
Old 02-01-2015, 11:35 AM
On most atvs its from the crank case vent that terminates into the air box. A lot of oil could be from accumulation over time or if running at an incline for extended periods,oil can work it's way up the vent tube and enter the air box and pool up. Usually the engine just takes the oily air from the crank case vent and recirculates it through the air intake system. Epa requirement now days.Plus that's what's the drain is for in the air box. To remove excess oil,water. Just check your air filter to see if it's oily,needs to be cleaned/replaced,plus check the vent leading into the air box and see if it has any type of filter that needs to be cleaned or replaced.
Old 02-01-2015, 12:38 PM
joust's Avatar
I will check for it.thanks a lot
exmotocrosser
09-13-2019 06:12 AM
1ArmBandit
55
10-14-2015 09:03 PM
Scooter's Shop
10-09-2015 02:09 PM
wrencher82
09-24-2015 03:39 PM
bvolks
09-13-2015 12:57 PM
Quick Reply: oil leak
