my honda 185s idles high
Old 03-02-2007, 11:58 AM
pineappleleroylej's Avatar
Default my honda 185s idles high
dont know why the 185s is idling high, i adjusted the idle screw out and still is idling high, i dont think there are any vacume leaks between the carb and head? any suggestions?
Old 03-04-2007, 12:26 PM
Madwolverine's Avatar
Check the throttle cable. If it is pinched or there is tension on the cable it could be "idling high" because the slide is open a bit. If that's not it take off the carb and check it out completely. Once I found that an o-ring between the carb and intake was missing on a 200x. This was causing me some trouble with the idle. I'd check everything while I had it out. (needle position, main jet, pilot jet, pilot screw, float...)
hugemoth
07-20-2020 03:28 AM
Nondem
02-22-2020 12:20 PM
ranvette
07-12-2015 06:34 AM
MNatv89
07-07-2015 11:36 AM
Quick Reply: my honda 185s idles high
