1982 185s won't start
Old 01-03-2012, 01:16 PM
chkmates12's Avatar
Default 1982 185s won't start
I just picked up a Honda atc that had been sitting for near 10 years and after cleaning out the tank, and carburetor , replaced all the hoses and added a new plug it won't start by using the pull, or even by trying to push start. It has compression, spark and is getting gas to the cylinder.
Old 01-08-2012, 09:19 AM
Check the valve clearance. The old Hondas used to tighten up pretty quick(at least for me) Think about .003 intake and exhaust? Don't know if this helps? OPT
Old 01-08-2012, 11:54 AM
chkmates12's Avatar
adjusted the valves and still nothing, I'm about ready to tear out the piston just to make sure everything is okay
Old 01-08-2012, 04:27 PM
Do a compression check first. If 100 psi or less then could be compression problem (valves leaking,seepage past rings) OPT
Old 01-13-2012, 04:29 AM
Robert.Connell's Avatar
Location: Gulfport, Mississippi United States of America
Spray some carb cleaner in it and if it will run for a second or if it sounds like it wants to run that's a good indicator that the valves are either out of alignment or not seating properly (that is where I would check first). You already adjusted the valves but it could be that they are not seating properly so you can re-lap them with some lapping compound and it will make a real nice seal. Usally if it burns off of the carb cleaner/starting fluid but not the gasoline you dont have enought compression so you have a leak some where. Usally valves are the place when this test but you could have a small leak in the gasket or piston area..
Hope this helps.
Old 01-22-2012, 05:21 PM
chkmates12's Avatar
checked the valves, and one of them was pretty well bent, could this be the reason why it wasn't starting
Old 01-22-2012, 05:24 PM
bartmann's Avatar
Banned
It's a 82 ....just junk it and buy new....
Old 01-23-2012, 07:50 AM
Just order new valves,have them lapped in along with new valve guide seals. Hopefully then will run.Order through Cycle Parts Warehouse.Around $75 for both valves and valve guide seals,plus you will need a new head gasket. For around $100 bucks total should be running again. OPT
MikeyBoyesq
11-27-2020 02:44 PM
garyt1975
06-05-2015 08:53 AM
1000gade
05-27-2015 12:37 PM
motoxer
03-14-2001 12:32 AM
JAW
01-23-2001 10:40 AM
Quick Reply: 1982 185s won't start
