Redcat reverse gear not engaging
Old 06-14-2015, 06:13 PM
supermanotorious's Avatar
Winchmaster 5000
Default Redcat reverse gear not engaging
Hey guys, I ended up buying the Redcat I was repairing for my neighbor. Now that its mine I'm going to address the rest of the issues. For starters, the quad will not reverse. The cable when engaged moves the gearbox lever but simply puts the quad in Neutral. Any ideas why? Here are pics of the Redcat, the VIN, gearbox, and the engine model if it helps.
Attached Thumbnails Redcat reverse gear not engaging-007.jpg   Redcat reverse gear not engaging-012.jpg   Redcat reverse gear not engaging-013.jpg   Redcat reverse gear not engaging-014.jpg   Redcat reverse gear not engaging-015.jpg
Old 06-14-2015, 11:48 PM
MPDano's Avatar
What model is it? My sons 70cc Redcat only had forward.
Old 06-15-2015, 08:43 AM
Winchmaster 5000
I believe it's the VX-200, it has the reverse lever which does move the arm on the gearbox
2006 Redcat Motors VX-200 ATVs
Old 06-15-2015, 09:22 AM
MPDano's Avatar
Sounds good. On my Baja theres is an adjustment on the linkage to get it to go into each gear (forward, neutral and reverse). If it goes into neutral and forward just fine, then the issue sounds like it's in the gearbox itself. You'll find that if the gears or forks are bad, you may not be able to get the parts. I would first see if they are readily available before tearing into it. You got forward and neutral and that's a plus. Reverse is more of a convenience.
Old 06-15-2015, 11:46 AM
Winchmaster 5000
I'll look, thank you
Old 04-20-2020, 01:14 PM
Eagle Lube's Avatar
I know i'm 5 years after the conversation, but I'm curious about what the outcome of the axle was? I currently have a 150 quad (identical) my gears all engage, forward and back. my tires will spin but will stop spinning as if not in gear. fluid level is full and chain is tight. any suggestions would be helpful.
Old 03-12-2021, 11:02 PM
Mookiebabii's Avatar
Default Mpx 110 redcat
Mpx 110 2006 redcat wouldn't start. Brought a brand new battery and it worked just fine all day. Later my son tried to ride and it wouldn't turn over. It will make the noise like it wants to cut on but wont.. Please help
jnagraves
07-03-2020 02:26 AM
stony30
03-28-2019 10:49 PM
JaCkaL829
04-10-2010 06:13 PM
MikeB82781
06-20-2009 10:45 PM
Quick Reply: Redcat reverse gear not engaging
