gas/oil mixture
Old 07-17-2015, 01:46 PM
ghost3's Avatar
Default gas/oil mixture
Help!!!
Working on a Kasea 150 atv for neighbor. Know it's a two stroke, but can not find anywhere what mix should be. Don't see oil reservoir or any connection where it would have attached to the carb.
Thanks for any info
Old 07-17-2015, 02:18 PM
Scooter86's Avatar
Knows Old ATV Questions!
In a pinch you could probably run 32:1 in it. Might make it a little lean if it was initially designed for 40 or 50:1. Hopefully someone will be along soon that has one.
Old 07-18-2015, 08:20 AM
LT80's Avatar
LT80 Expert
I'd run 32:1
I didn't know they made a 150 2 stroke. You sure?
Old 07-19-2015, 01:11 PM
MPDano's Avatar
Yup, 32:1 unless known otherwise. This is the safest as it's more oil. All my KTM's run lean at 40:1.
Old 07-19-2015, 01:13 PM
MPDano's Avatar
I too would also verify 2 or 4 stroke. The head looks different on a 4 stroke as it houses valves. Also, the pipe will look different.
Old 07-19-2015, 08:46 PM
LT80's Avatar
LT80 Expert
I can't find any info on 150 2 strokes.
My money is on it being a 4 stroke.
kelleycully
09-15-2016 02:57 AM
rockinkgin
09-25-2015 01:52 PM
MikeyBoyesq
09-22-2015 10:02 AM
MikeyBoyesq
09-07-2015 10:44 PM
goosemasterkl
08-23-2015 11:36 AM
Quick Reply: gas/oil mixture
