1987 Polaris trail boss 250 4x4 Need help!!!
Old 03-31-2015, 03:22 PM
ryan420h's Avatar
Default 1987 Polaris trail boss 250 4x4 Need help!!!
whats happened is my rear chain broke and I realized my inner sprocket was missing teeth, that runs the back tires. How do I remove this sprocket? I have taken the outside one off for the front wheel, but there is a bearing flange and bearing behind there I have the flange off but how do you pull the bearing and the part behind it off? Or do I need to pull the whole motor apart to reach this sprocket any help would be great!!!
Old 03-31-2015, 03:51 PM
Have to remove the two bolts on the bearing flange,plus if it still has the small collar behind it,takes a 1/16" or 1/8" allen head to loosen the socket screw so it can be removed through the frame cut out also. Sprocket is held on by a small snap ring. Just remove it and slide the old sprocket out,new one in. SOME bearings and flanges are frozen from being on so long as you've noticed! Be aware that you may have to beat it up to get it off..Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old 03-31-2015, 06:31 PM
ryan420h's Avatar
Okay so that bearing if it gets damaged you know how to find a replacement all the sites seem to not have it available.
Old 04-01-2015, 04:16 AM
They still have em,but updated part# and not cheap.Item #3 same as on this 92 model and your model also.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Plus they have them on ebay.Fits several different machines.http://www.ebay.com/itm/NEW-OEM-Polaris-Bearing-Kit-1999-Xplorer-300-2201115-NOS-/251444609569?pt=Motors_ATV_Parts_Accessories&hash=item3a8b444221&vxp=mtr
Old 04-01-2015, 12:10 PM
ryan420h's Avatar
Thank you very much. I have been trying for a couple weeks now for some help thank you!!
Nondem
02-22-2020 12:20 PM
Gtsordo
07-13-2015 10:38 PM
steveo612
07-11-2015 08:35 AM
yambam13
07-04-2015 01:49 PM
bzdok1234
Utility ATVs
07-03-2015 05:32 PM
Quick Reply: 1987 Polaris trail boss 250 4x4 Need help!!!
