atv help
atv help
I have a problem with a 90 cc . So i can turn it on fine but when I switch it up to 1 to take off and push the throttle it makes a loud noise as if where going real fast but it moves slow worst when I try going to 2 and 3 it's a Chinese brand and I don't know much about atvs yet but I'm learning any tips advice help is greatly appreciated
2 things to check into. Not sure if yours has a cable operated clutch on the bar but make sure that is not adjusted to tight, should be some slight play in the cable. If its auto their may be another place to tighten up the clutch if its slipping. Also any idea what kind of oil may be in it? May not be clutch safe oil. Had a old kingquad that someone had just tossed in what ever they had. Slipped like crazy did a few oil changes on it and it was much better. Still slipped slightly but was rideable
There is no hand clutch only a foot gear lever bit now that I think about it the lever did get stuck a few time right now they switch up and down fine its just when I switch it up to 1st to take off it make a loud exaggerated Rev noise and doesn't move fast at all worse on 2nd and 3rd doesn't even move just makes the loud Rev noise ... thanks old polaris tech
