2003 Polaris sportsman 500 no power at ignition
Old 09-26-2015, 09:30 PM
Jackg17's Avatar
Default 2003 Polaris sportsman 500 no power at ignition
Recently replaced the starter, bendix, and solenoid and the machine was running fine. The. Suddenly it began cranking infinitely. Would start fine but continue to crank when started and even with key off. Had to disconnect the battery to stop it. I assumed the solenoid had stuck. So I changed the solenoid again and now I have nothing. No lights, no crank, nothing. If I cross the solenoid with a screw driver it will crank and the pod lights come on. I have disconnected the key switch and using a multimeter I am not getting any power to the switch. Any thoughts?
neilbedwell
11-10-2018 11:02 AM
Thanos
07-12-2015 08:40 PM
yellowpolaris
06-21-2015 11:13 AM
DOAinNY
06-11-2015 10:34 PM
05-27-2015 11:15 AM
Quick Reply: 2003 Polaris sportsman 500 no power at ignition
