2008 polaris rzr 800 battery problems
Old 06-20-2016, 08:08 AM
bwalker2's Avatar
Default 2008 polaris rzr 800 battery problems
when we run this vehicle we notice that the fan stays on for a long time and causes our battery to run low and then not able to crank. Could the stator not be working properly or could we have a engine cooling problem, radiator is clean and we have a brand new AGM battery on there
Old 06-20-2016, 08:28 AM
First off at an idle check that the battery is charging 14-14.5 volts. If not this could be the reason why the battery is draining down if charging is below this voltage. Could be a faulty regulator if it isn't. Item #18(according to build date)Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old 06-20-2016, 08:33 AM
bwalker2's Avatar
ok I will check it out we have a little over 1100 hours on vehicle and things are starting to gove out thanks for the help sir
Old 06-20-2016, 08:41 AM
Make sure on build date of your machine as part numbers could be different if any parts need to be ordered. Vin # to any dealer can give you that info if you don't have the original built sheet that came with the machine.
Old 06-20-2016, 09:08 AM
bwalker2's Avatar
I don't have a build sheet its for the ranch we live on and we go through some of the roughest rock crawling terrain.(it dosent just bend out here, it breaks)Val verde County, TX
Old 06-20-2016, 12:19 PM
Then call a dealer with your vin# and they'll tell you right quick..
Old 06-21-2016, 03:21 AM
bwalker2's Avatar
thank you
wanttoride1
04-27-2016 02:24 AM
superfly85
04-26-2016 06:35 PM
Ray Bourbeau
04-18-2016 08:13 PM
chrisarvor
1) Engine problems..
03-31-2016 01:41 AM
Quick Reply: 2008 polaris rzr 800 battery problems
