Recon ES / Trouble Shooting / Dash Lights
Old 10-06-2004, 01:45 PM
Ball's Avatar
Default Recon ES / Trouble Shooting / Dash Lights
The dash lights/Gear selected display light flash on my 02 Recon ES and I am sure this is a trouble shooting tool to let you know that there is something wrong. Does anyone know what exactly the lights mean?
Old 10-06-2004, 03:43 PM
hondabuster's Avatar
Yep, on 02 and up, they flash a code. I dont have a manual for the recon, but one for a foreman. They might be the same. Whats the symptoms? Does it ever clear out? If you use the shifter, and manually get to neutral, then go key off and back on..does it flash? how many flashes?
Old 10-06-2004, 05:23 PM
Ball's Avatar
It flashes 1st gear continuously. The only way to get the quad to shift is to turn off the key and turn it back on. Within a few seconds it starts again. Can you help me?
Old 10-06-2004, 05:30 PM
When its in neutral, itll flash? does it flash, - - ? How many times?
What are the symptoms? were you just cruising along, and it stuck in gear and wouldnt change? When you use the handle, to get back to nuetral, will going key on and off,reset the flashing?
Old 10-06-2004, 05:33 PM
Ball's Avatar
The key will reset the flashes only for a few seconds. The symptoms are that it will not shift up or down while it is flashing. I will go see how many times it flashes........................................... ...................
Old 10-06-2004, 05:47 PM
Ball's Avatar
I can't get it to flash at all now......Figuires.
Old 10-07-2004, 02:18 PM
It happens. Some things to check.
Proper oil, and proper amount in crankcase.
Good battery.
Clutch adjustment.
Old 10-07-2004, 10:53 PM
Lighthouse's Avatar
first gear blinks
1 Blink ECU ( writing and recording circuit )
2 Blinks ES shift switch system ( up and down )
3 Blinks Angel sensor
4 Blinks Gear positiom switch system
5 Blinks ECU motor drive circuit
6 Blinks ECU fail safe relay circuit
7 Blinks ECU voltage converter circuit
8 Blinks Angle sensor system
9 Blinks Angle sensor system
10 Blinks ignition pulse generator system
11 Blinks speed sensor system ( vehicle speed )
12 Blinks gear positiom switch system
All blinks showen on the ES models are showen on the first gear indicator
Hope this helps a bit
John
Old 10-08-2004, 07:32 PM
brimmer's Avatar
Im having the same problem with my recon if you figure it out could you let me know thanks
Old 11-18-2007, 02:21 PM
bucky_webb's Avatar
Mine blinks 8 usually and blinks 3 on occasion. So according to the chart above it's the Angle Sensor (System). Anyone know what this means? How to fix it? Is it a do-it-yourself fix or will I need to take it to the shop?
Quick Reply: Recon ES / Trouble Shooting / Dash Lights
