angle sensor
angle sensor
Angle sensor is on front of engine casing - facing forwards behind a metal cover with two 10mm bolts that hold it. you can disconnect the battery , switch off the petrol , and put it up on the back rack. then when you look in over the bash plate it is straight in front of you.
if you change it out, make sure you replace the rubber 'o' ring -- and keep everything clean.
Jeff Roper
02-01-2022 11:48 AM
jrooker6
04-23-2016 07:36 PM
