02 400ex HELP! ASAP
02 400ex HELP! ASAP
Ok so i have a 2002 400ex it has a big gun exhaust thats all suposedly it has a jet kit but after it came out of the shop the jets look the same as they did when the quad went in to the shop
Anyway cutting to the problems here is a list
1. in neutral the quad revs fine BUT it does not hit rev limiter the normal rev limiter should be budadadadadad mine is buda......buda...........buda.......buda
2. When in first gear the quad will not hit high rpms when you get in to high rpms it seems like the quad is turning itself off until you release the throtle but it will not go into high rpms its almost like if you were in high rpms and then you toggled the kill switch its the same noise and everything
any help would be appreciated and if any one has the jet settings for all the jets that would be great like for every single jet how should it be configured?
how many turns for the main pilot air fuel all of them!
Thanks
IF YOU NEED A VIDEO TO UNDERSTAND I WILL MAKE A YOUTUBE VID
Thanks
and bengear90 the shop is trash they stole parts off of it while it was sitting there and put faulty parts in it came out with more problems than it went in with they also rode the **** out off it and blew my rear shock and melted my plastics a bit they also charged a massive storage amount when they said they wouldnt
