Rancher slip differential a letdown....
BigBear....after using my rancher more and more, i do see that it is better than the old slip diff when all four tires are on the ground....and i can now get the tire with traction to grab (using the braking trick) when one tire is in the air.....but it rarely makes a difference as by that time you've lost momentum and are stuck...too late.
Jeff Roper
02-01-2022 11:48 AM
