LT80 tuning issues
Old 07-05-2012, 07:00 PM
SLOW's Avatar
Default LT80 tuning issues
I have several lt80's all are stock. I decided to slightly modify the oldest one a 01.
Mods are uni filter, reed pedal, 32 to 1 premix (amsoil oil) and a dg pipe.
Stock jetting. I have gone over the carb and cleaned it. Needle clip on the second to last position since it seemed to be running lean.
Quad is breaking up under acceleration. Seems down on power compared to my stock 04,05,06. Compression is 120 + on the 01. I had all the mods on except the pipe and it ran pretty strong after the pipe it seems the power went down and the breaking up got worse.
Also bike fires right up with no issues and never needs to be choked is that odd that it never needs the choke because all my other bikes like it when there cold.
I am going to go over the wiring tomorrow and check to see if something is cut this 01 was a basket case when I got it
Thanks for the help guys
Old 07-05-2012, 08:54 PM
LT80's Avatar
LT80 Expert
I think that I'd remove a carb from another LT and try it.
If nothing changes, maybe try swapping the CDI and/or coil.
Maybe try the stock pipe again...?
At least you have running machines to try parts from.
I'm curious, I hear of most Amsoils being used at 50:1 to 100:1
I'm wondering if the 32:1 mix could be causing a fuel/mix problem. What's the bottle say?
Old 07-05-2012, 09:23 PM
SLOW's Avatar
Going to coil and cdi tomorrow. I might go with the 50 to 1 with amsoil. I got the dg pipe off another bike man its loud it might be coming off. I dont think its the carb but I might swap. Just going to so one thing at a time to narrow the problem.
Old 07-06-2012, 06:51 AM
LT80's Avatar
LT80 Expert
I call the DG pipe a stock replacement. Just a bunch of noise.LOL
Old 07-06-2012, 11:58 AM
SLOW's Avatar
Yank the dg. Put a different coil on that seemed to be the trick. Goint to go through carb just to be sure.
Thanks
COFatboy
05-02-2020 12:06 AM
Bergmann
08-13-2015 03:51 PM
Ashley S
08-06-2015 12:56 PM
cornermike
07-30-2015 06:37 AM
Unzzy66
07-11-2015 10:01 PM
Quick Reply: LT80 tuning issues
