LT-Z50 Drive Belt tips needed please.
Old 03-19-2015, 04:34 PM
MajorGasAttak's Avatar
Default LT-Z50 Drive Belt tips needed please.
Can someone give me a few pointers on changing the drive belt on a 2006 Suzuki LT-Z50. I took a real quick look the other night and the clearance I'm used to seeing on a snowmobile does not exist. Does the front clutch need removal? Any vehicle specific info would be great! Thanks.
Old 03-20-2015, 08:04 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
You take the front outer face off then you can r&r the belt.
If for some reason you cannot get it off the rear (usually a clearance problem if any) simply remove the rear clutch too.
looking at part fiches helps.
OEM Parts
Old 03-20-2015, 03:13 PM
Thanks LT80. I've read I may need a special dealer only tool to remove the front clutch, AKA an air gun! Belts arrived today, bleeding knuckles tomorrow!
jrooker6
Ask the Editor
11
04-21-2016 07:35 PM
rcappie4
06-07-2015 02:53 PM
flatcroaker
05-27-2015 05:57 PM
Joeg
09-27-1999 11:53 AM
Quick Reply: LT-Z50 Drive Belt tips needed please.
