Dinili Engine Identification
Old 04-09-2015, 12:57 PM
lsukevinc's Avatar
Default Dinili Engine Identification
I own a 2004 Dinili Diamondback 50CC. I am in the process of changing the carb and possibly making it a 70cc. I pulled the side cover off yesterday looking for an engine identification number, and I could not find anything. I am searching online and coming up with nothing. According to a few websites, it should be stamped on the plastic left engine cover or the left belt cover, but I cannot find it either place. Does anyone know if the 2004 is a JOG, minarelli, etc, or where the engine id is stamped. I was able to find the frame's vin number and a few number off of the block.
Old 04-09-2015, 07:47 PM
LT80's Avatar
LT80 Expert
yup...jog minarelli, etc. ebay lists them as the same.
You'll need a pipe.
Try hetrickracing.com They can fix you up w/everything.
Old 04-10-2015, 09:43 AM
lsukevinc's Avatar
so turns out the compression was low, about 60 psi to be exact. So now to replace with stock 50cc or more up to a 70 big bore kit?
Old 04-10-2015, 03:32 PM
LT80's Avatar
LT80 Expert
It depends on what you want when done.
It looks like the 70 kit isn't much if any more $ than a 50 kit.
Old 04-16-2015, 10:06 AM
lsukevinc's Avatar
I installed the big bore kit last night. the only question I have is the head gasket. The new aluminum head has a groove for an o ring which was included. Also included was a thin aluminum gasket with a grove stamped in to match the diameter of the o ring. Do I install the aluminum gasket to the stamped lip compresses the o ring or install it so the o ring sort of fits in the stamped ring?
One video, and one step by step website I viewed only showed the installation of the o ring and not the o ring and gasket. Any help is greatly appreciated.
Old 04-16-2015, 07:49 PM
LT80's Avatar
LT80 Expert
I've never seen a o-ringed head use anything along with the o-ring.
The other is a stock style gasket.
Arrow toward exhaust, right?
100 inch pounds on the head nuts.
jeepwheelin02
1) Engine problems..
07-18-2020 06:42 PM
Cummins Driver
09-11-2019 01:22 PM
austinwhitton
08-11-2015 06:21 PM
07-30-2015 09:39 AM
KimSJoh
14
07-18-2015 07:20 PM
Quick Reply: Dinili Engine Identification
