2001 Suzuki Lt80 no start just cranks
Old 09-15-2015, 01:25 PM
QuadRiders's Avatar
Default 2001 Suzuki Lt80 no start just cranks
Pulling my hair out here! My daughter was coming up the drive way and her lt80 stalled and she coasted right to me. looked like about out of gas. put gas in. Since that moment this thing will not restart. Pulled plug and found it is bone dry. Found somehow the vacuum line cam off carb going to petcock. removed carb and cleaned several times which i did find the pilot jet and passage was pretty dirty. I have good spark, 100 psi compression, and still know fuel at plug. Pulled reed valve and it was lifted up a slight amount so I turned over and reassembled. I do feel vacuum from the one port on carb during cranking. I keep wanting to pull the carb back off and clean. I bought it with in inline fuel shut off already installed because I think there was an issue with factory shut off. Any ideas?
Old 09-17-2015, 08:32 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Which port do you feel the vac?
Try hand choking it (2 fingers in front of carb).
Old 09-17-2015, 08:46 AM
QuadRiders's Avatar
I felt vacuum from the port next to the supply port. Its for the hose that goes back up to petcock. I did try the two finger method and not even a hick up. I pulled the side covers off to see if I could see the crank seals but I cant see with out grabbing a puller from work and removing flywheel and gears
Old 09-17-2015, 02:35 PM
LT80's Avatar
LT80 Expert
Put the petcock on prime position and see if fuel flows thru the line to the carb.
Old 09-21-2015, 07:29 AM
QuadRiders's Avatar
Fuel is coming out with the prime position. Took carb apart and cleaned one more time. Still no fuel at spark plug.....
Old 10-22-2015, 04:13 PM
DirtDevil101's Avatar
does it run on ether? that's the easy check if it's your fuel system or something else...
njrider64
07-04-2017 01:40 AM
Big600twin
14
06-16-2015 09:30 AM
Jbird4681
06-09-2015 01:59 AM
Dieseltrash
06-01-2015 06:53 AM
1000gade
05-27-2015 12:37 PM
Quick Reply: 2001 Suzuki Lt80 no start just cranks
