wont run after started
i bought a 2002 cannondale that will start and idle for a couple of seconds, but not run on its own.it will cut off as soon as u hit the throttle.i can feed it gas manually by spraying gas into the intake with a spray bottle.i checked fuel pressure it had about 55psi the bike has brand new injectors still having the same problems.
please help
please help
Do you have a D&M kit or know someone that does? It could be a setting of the ECU. I would also look at the coil, because of the location you might have a cracked one due to age and heat. This would give you a weak spark and may not allow it to run.
If you log onto Cannondale rider dot com or Cannondale central dot com there are much more knowledgable people there who should be able to take care of you. Heck they may even live close and will stop by or allow you to bring it to them.
Smitty
Smitty
we checked all of the wires and the plugs,we fond a wire that was broken that went to the throttle body we fixed that and when we put the bike back togather we started,the bike ran and idled alot longer but still when we hit the throttle it still wants to cut off but the bike will stay running
