reverse light problems
Old 05-24-2011, 03:28 PM
montie1984's Avatar
Default reverse light problems
Hello I'm new to the site and have a couple problems and wondering if anyone has had the same problems. First off I have a 2000 polaris sportsman 500 that has the following symptoms:
1) goes as fast as i want in reverse but seems doggy in high gear.
2) when i push the reverse override button in with key on engine off, the reverse indicator light lights up no matter what gear im in.
3)the speedo needle doesnt move and the miles dont accumulate but the hour meter and the back light works.
4)when in netrual or reverse, the indicator lights dont want to work.
The speedo was just replaced and i have torn the machine apart to look for fuses or bad grounds but cant find anything that appears bad. The quad has a reverse light kit and a winch. The winch works fine but the reverse lights only work when the reverse override button is pushed. Im leaning towards getting a speed sensor to fix the speedo problem but not sure if i have a bigger problem that would effect all the above. Please let me know what i can try next. Thanks in advance.
Old 05-24-2011, 03:37 PM
Speedo sensor will probably be the fix on speed and mileage(common problem for them to go out)
I would check the connections on the the two transmission switches,plus could have a short in left control switch causing some of the problems. Plus its not uncommon for a trans switch to be faulty(plastic levers can break inside switch) Trans Switch or wiring could be cause on no reverse lights? Plus goes ok in reverse but doggy in drive?? Could be a clutch or belt problem?? OPT
Old 05-24-2011, 04:16 PM
montie1984's Avatar
Is there a way to test the speed sensor? The plastic tranny connectors look good and the plugs look clean, is there something I could do to check the sensors in the tranny? When I said it seemed to run boggy in high gear I was just trying to say it seemed the rev limiter is kickin in when going forward but not in reverse. Would that be in the switch.
Old 05-24-2011, 04:32 PM
You have to remove the transmission gear indicators to see if plastic arm is broken. We had a dealer supplied harness that can check the speed sensor,BUT 9 out of 10 times when speed and mileage doesn't work its a shorted sensor! Can limit in forward if its not getting a positive FORWARD gear position! Could be as I've said a short in the left control switch OR in the wiring going back into the headlight pod area! I've found shorted,broken wires in the harness down from the left control switch connectors that can cause some of your problems ?? Electrical problems are a process of elimination and not always cut and dry. OPT
toonces
10-16-2019 12:11 PM
bzdok1234
30
02-23-2016 01:55 PM
tweeder
07-05-2015 01:57 PM
bikedad3
07-02-2015 02:15 AM
Nowinsky94
Technical and How-To Articles
05-27-2015 07:29 PM
Quick Reply: reverse light problems
