Engine swap
Engine swap
I have a 2003 sportsman 600 and I was wondering how hard or if it was possible to find a used 700 motor from like a 02, 03 or 04 and swap it in. Nothings wrong with my 600 motor just want something a little bigger and I don't wanna get rid of my wheeler. If I could swap it without much trouble I'd maybe put some hot cams or something in the 700 to get as much out of it as I can. Just curious!
The kit for the 600 was Kokusan #2202603. For the 700 it was #2202602. I honestly don't know if the 700 kit would work on the 600 wiring harness and vice versa.If it did,I'd expect some rigging and no guarantee that it would run right. You're really getting into cross breeding to the extreme.
Stator would bolt up to the 700 as well as the new cdi and new regulator on the 600 kit would work on your harness and hook up with no problems. The thing is I don't know if the ignitions are exactly the same on the 600 and 700 such as timing,electrical advance,etc. Probably will work,but there's always the unknown when doing this.
